Mixalis Posted June 13, 2020 Posted June 13, 2020 I have a defender 90 1991 model and i want to change the air filter but i want to put a performance filter. I want to remove the air filter box and put a round tapered air filter. This modification will make problems to the engine? How much air 200tdi engine needs? and this will give me more power? Quote
hurbie Posted June 13, 2020 Posted June 13, 2020 if you have a original 200tdi , i will buy your airfilter box ! i don't think you will gain horsepower from a "performance" filter , you will get more noise .... Quote
Snagger Posted June 13, 2020 Posted June 13, 2020 Hurbie is right. All that these “performance” filters do is let more noise out and more dust in. Quote
Mixalis Posted June 14, 2020 Author Posted June 14, 2020 @hurbie so the engine is gonna work well with all kinds of air filters without problem? Quote
western Posted June 14, 2020 Posted June 14, 2020 Better for the engine to stay with the standard factory air cleaner system. you haven't said which 'performance' air filter you were looking at fitting, so other members/owners can't really give a good reply. Quote
Geojake Posted June 15, 2020 Posted June 15, 2020 On 6/13/2020 at 5:37 PM, hurbie said: if you have a original 200tdi , i will buy your airfilter box ! i don't think you will gain horsepower from a "performance" filter , you will get more noise .... @Mixalis standard 200 tdi air filters are like rocking horse shiit - impossible to source so do not get rid of it!! The previous owner of mine did and I had extreme difficulty getting one back. Quote
Ex Member Posted June 15, 2020 Posted June 15, 2020 (edited) 5 minutes ago, Geojake said: @Mixalis standard 200 tdi air filters are like rocking horse shiit - impossible to source so do not get rid of it!! The previous owner of mine did and I had extreme difficulty getting one back. Actually you can buy repro units. Not cheap, but available. https://www.ebay.co.uk/itm/Off-Road-4x4-Land-Rover-200tdi-Air-Filter-Housing-Case-Bracket-OBPXAFB01-/172367282809 https://www.ebay.co.uk/itm/obp-4x4-Air-Filter-Housing-Defender-200-Tdi-OBPXAFH001/173603416048 Edited June 15, 2020 by Red90 Quote
hurbie Posted June 15, 2020 Posted June 15, 2020 5 minutes ago, Geojake said: @Mixalis standard 200 tdi air filters are like rocking horse shiit - impossible to source so do not get rid of it!! The previous owner of mine did and I had extreme difficulty getting one back. that's why i need one .... 200tdi in my 110 , no airfilter box 😞 Quote
Nonimouse Posted June 16, 2020 Posted June 16, 2020 Just get a 200tdi Disco air box - still rare, but not that rare Quote
Mixalis Posted June 16, 2020 Author Posted June 16, 2020 @Nonimouse what different disco air box have than the defender air box Quote
Ex Member Posted June 17, 2020 Posted June 17, 2020 Just stick with the stock setup. It make life much easier to not have random custom stuff. 1 Quote
Maverik Posted June 17, 2020 Posted June 17, 2020 Get some searches set up on ebay - you just missed out on a 200tdi Defender air cleaner for £60, they do come up. Quote
Nonimouse Posted June 17, 2020 Posted June 17, 2020 14 hours ago, Mixalis said: @Nonimouse what different disco air box have than the defender air box There's two defender ones - but not on the part lists... There's one very similar to the Discovery/RRC 200Tdi wing mounted style Then there are a number of Genuine Factory vehicles that are fitted with the TD style upright canister. Note: Discovery/RRC 200tdi take a different filter to the Defender Tdi of virtually identical shape Quote
Nonimouse Posted June 17, 2020 Posted June 17, 2020 9 hours ago, Red90 said: Just stick with the stock setup. It make life much easier to not have random custom stuff. He doesn't have the OE Quote
Ex Member Posted June 17, 2020 Posted June 17, 2020 43 minutes ago, Nonimouse said: He doesn't have the OE He says it is a 1991 model, so should be factory normal. No point in changing. Quote
Snagger Posted June 17, 2020 Posted June 17, 2020 Much better to spend the money you considered for suspension and big tyre mods for this, even if you get stung on overpriced sales. The correct casing will protect the filter from mud and water splashes and a lot of dust. Open filters get clogged and damaged very quickly. Quote
Snagger Posted June 17, 2020 Posted June 17, 2020 1 minute ago, Red90 said: He says it is a 1991 model, so should be factory normal. No point in changing. It sounds like a previous owner has removed it. 1 Quote
Ex Member Posted June 17, 2020 Posted June 17, 2020 1 minute ago, Snagger said: It sounds like a previous owner has removed it. Where does he say that? We are talking about Mixalis here. That is who Nonimouse replied to. Quote
Snagger Posted June 17, 2020 Posted June 17, 2020 You’re right - I must have another similar thread in mind, or I’m just losing it... Quote
kevin50 Posted June 17, 2020 Posted June 17, 2020 Think Ihave a 200 Air filter box somewhere . Didn't know they were that hard to find. Quote
Nonimouse Posted June 17, 2020 Posted June 17, 2020 1 hour ago, Snagger said: You’re right - I must have another similar thread in mind, or I’m just losing it... No, it was mu bad - I was mixing this up with another thread. Once again Red 90 was on the ball Quote
Snagger Posted June 20, 2020 Posted June 20, 2020 No - it’ll let an awful lot of dust through and will be very noisy. You will much better protect your engine with the standard equipment. This and suspension are absolutely classic examples of expensive items marketed as upgrades which markedly downgrade the vehicle unless you have very specific and unusual circumstances. Don’t be tempted to change much on the vehicle unless there is a very clear reason to - there are aspects that were made cheaply and poorly, but that mostly manifests in corrosion or broken parts. But the design was proven over many decades and hundreds of thousands of vehicles with minimal changes other than the engine and primary gearboxes because they were right for the vast majority of users from the start. Accessories and comforts are a little different, but most of the mechanical related stuff was pretty well designed. The Rover differentials and front shafts were one of the few exceptions, but they’re not terrible, just don’t stand a lot of very hard off reading indefinitely. You'd be far wiser to run the vehicle as standard for a while and find what doesn’t work for your circumstances than to jump in at the deep end and make changes without really knowing the vehicle and it’s behaviour. Besides, any vehicle is going to have age and wear related issues to fix before alterations are prudent. 1 Quote
Jocklandjohn Posted June 21, 2020 Posted June 21, 2020 (edited) My local LandRover independent expert made a simple suggestion (he's built numerous LR's for customers and owns several LR's in the family which he has built or renovated, his daughter has a custom V8, he has a TD5 Disco, his wife has a 300tdi 110, and he also uses a home-made and tuned frankenstein hi-cap/double cab for his 'other' farming work) - if you have the standard round tube airfilter box (I've got a 200tdi with the 2.5TD/19J filter setup) you'll see the lower section of the filter is covered with plastic with those fins around the bottom - simply cut some of the plastic off. He explained that by removing some of the plastic you increase the amount of filter exposed and thus the amount of air thats able to be drawn into the engine, and its still filtered properly. I tried it and it made a little difference - running cleaner (a bit less smoke) and a bit more pull as well. Not vast of course, but still noticeable. For the cost of a filter its worth a try. Given I'm not running in hugely dusty conditions the absence of the swirly fins at the bottom isn't a problem. If I was going to be running in really dusty situations I'd leave it as it is, as the design is like that for a reason! Edited June 21, 2020 by Jocklandjohn 1 Quote
PumaPete Posted January 12, 2021 Posted January 12, 2021 I have a filter which is for a 200 Tdi that I ordered by mistake. It has the plastic bit with the fins on. I actually need one for a 300 Tdi. Are they the same, or should I remove some or all of the clastic bit? Quote
