Posted (edited)
Hi. I’ve just started inspecting a Discovery 200tdi engine I’ve had for years with the intention of fitting it into Ninety.
We have taken off the oil pump and found the drive shaft has a tooth ground off it.
Is this usual and done by LR or am I looking at a modification done by someone?
Edited by Ian Barrett
Posted (edited)
I’ve found a photo on another forum which confirms this is a normal thing.
onwards and upwards then. If we can get the pulley bolt off we are taking the pistons and crank out this morning to see how worn things are.
