Jim Mason Posted September 22, 2021 Posted September 22, 2021 Hi all, Got a snorkel fitted for sometime on the landy, with the air inlet facing the road. But curious if this is the correct way to have it as recently had a lot of black smoke and found the air filter damp and a little mouldy in places. Thinking of having it rear facing. Also just covered with square mesh as i keep finding blue tits inside the air box. Curious on peoples thoughts on which way it should correctly face... Quote
SPendrey Posted September 22, 2021 Posted September 22, 2021 I used to have mine facing forward, with a grill on, and found that when laning in dense foliage (lots of bushes!) I'd get leaves blocking the entrance as they stuck to the grill. So, I now run mine open and angled over using a 180deg pipe, e.g. aligned to the upward slope of the windscreen. I also change my air filter every 6 months, even if it looks new. Usual contents is bits of leaves. Must say, your filter looks really old! Quote
Jim Mason Posted September 22, 2021 Author Posted September 22, 2021 Filter isnt all that old, done 3000 miles since last service as i service landy every 5000 miles... Its possibly 12 months old if that, misplaced notebook so cannot give exact date. Its due another service, get the next few weeks out of the way then it will be due a service. Finding filter always looks like this hence question over direction it should face. Dont do much green laning these days its purely for when flying my bird of prey and crossing farm land Quote
Jim Mason Posted September 22, 2021 Author Posted September 22, 2021 SPendrey, would you mind sharing an image of how you have yours please. Quote
Jim Mason Posted September 22, 2021 Author Posted September 22, 2021 14 minutes ago, Bowie69 said: Have you been wading? No mate... Air box is fully sealed just in case... Quote
Nonimouse Posted September 23, 2021 Posted September 23, 2021 Did you seal up the drain plug in the air box? It should never be sealed - ever Quote
Maverik Posted September 24, 2021 Posted September 24, 2021 All the Camel Trophy Discovery's had the snorkel head facing backwards, most of the modern ABS plastic type Land rover raised air intakes have the vent facing backwards. Quite simply - turn it around and see how you get on. I don't think there is a right or wrong way of installing it as such. - it certainly shouldn't cause you any induction issues. Quote
Nonimouse Posted September 24, 2021 Posted September 24, 2021 2 hours ago, Maverik said: All the Camel Trophy Discovery's had the snorkel head facing backwards, most of the modern ABS plastic type Land rover raised air intakes have the vent facing backwards. Quite simply - turn it around and see how you get on. I don't think there is a right or wrong way of installing it as such. - it certainly shouldn't cause you any induction issues. That was because in heavy foliage, leaves get sucked accross the face of the intake. Early CT were all mushroom heads (upto 1990 Discovery), which, due to the centrifugal effect, spin out any water ingested Facing foward you do get a lot of rain water intake - wheras backwards it is reduced somewhat. With a Donaldson type. all the water ingested, is spun out and then leaves through a drain hole in the head Quote
Sabre Posted September 26, 2021 Posted September 26, 2021 Interesting topic. I think the standard 300Tdi Disco's air filter element is too small for dusty conditions. Having travelled a few times behind other vehicles on dirt roads, I got into the habit of shaking clean the air filter element every night. And I was always surprised at the amount of dust in the filter element. When I re-bored the engine at 396k km, I could just get a clean bore at 2nd oversize The obvious solution would be to fit a Donaldson, as per Defender, but space is a problem. Would a snorkel alleviate the problem ? When we travel on dirt roads, the dust go much higher than the roof of the vehicle, hence my doubt about the effectiveness of a snorkel to reduce the dust burden on a filter element. I would appreciate the informed wisdom of this forum 😉 Quote
Nonimouse Posted September 27, 2021 Posted September 27, 2021 11 hours ago, Sabre said: Interesting topic. I think the standard 300Tdi Disco's air filter element is too small for dusty conditions. Having travelled a few times behind other vehicles on dirt roads, I got into the habit of shaking clean the air filter element every night. And I was always surprised at the amount of dust in the filter element. When I re-bored the engine at 396k km, I could just get a clean bore at 2nd oversize The obvious solution would be to fit a Donaldson, as per Defender, but space is a problem. Would a snorkel alleviate the problem ? When we travel on dirt roads, the dust go much higher than the roof of the vehicle, hence my doubt about the effectiveness of a snorkel to reduce the dust burden on a filter element. I would appreciate the informed wisdom of this forum 😉 Try a Donaldson head first - it's relatively hig maintenance and does need a snorkel to fit to. Option two would be to go Aussie style and fit a precleaner up on the roof - 200Tdi syle would do 1 Quote
Jim Mason Posted October 8, 2021 Author Posted October 8, 2021 Great replys very well written & thought about thank you... 1 Quote
Sabre Posted October 12, 2021 Posted October 12, 2021 On 9/27/2021 at 9:08 AM, Nonimouse said: Try a Donaldson head first - it's relatively hig maintenance and does need a snorkel to fit to. Option two would be to go Aussie style and fit a precleaner up on the roof - 200Tdi syle would do Good idea, thanks 👍 Quote
