Skyerider Posted October 5, 2021 Posted October 5, 2021 (edited) No headlights, neither high nor low beam. Sidelights only. Bulbs fine, high beam flash works. Headlight symbol on dash comes on when it should. As there’s no fuse that I can see for the headlights I’m guessing its a relay. Is this something that a non-technical person can check (maybe swap relays?) or should I go 120 miles to the nearest Indy LR expert. All suggestions welcome! Edited October 5, 2021 by Skyerider Quote
bear Posted October 6, 2021 Posted October 6, 2021 Hi, Sorry I don't have the D4 (mines a D2) but my first action would be to swap the the relay to rule that out first. Then check the light switch is ok. Griff 1 Quote
Skyerider Posted October 6, 2021 Author Posted October 6, 2021 Problem solved - my fault - two blown bulbs and the spares I put in were faulty. … lesson learned (until the next time … 😊) 1 Quote
missingsid Posted October 6, 2021 Posted October 6, 2021 As stuff gets more complex and computerised it is very easy to look too hard. Quote
