Naks Posted January 15, 2022 Posted January 15, 2022 Hi all, This happened twice in two days, after starting the car the first time in the day (ambient +-34C). Video: It doesn't happen after driving around and then starting the car again. I went past my mech yesterday, and he tightened the bolts on the brake booster. They were not loose, but there was some give in them. Funnily enough, I saw the replies to my question on another two forums, and got similar feedback. Someone posted this TSB, which affects the booster, it may be helpful to others: https://www.rrsport.co.uk/gallery/albums/userpics/23569/SB-10106336-9340.pdf "Reference: SSM72903 Models: Range Rover/ L405 Range Rover Sport/ L494 Title: Air Leak Noise When Brake Pedal Is Pressed Category: Chassis Last modified: 29-Jul-2016 00:00:00 Symptom: 301000 Service Brake System Attachments: D7u Booster Fixings Secure Sequence.pdf (D7u Booster Fixings Secure Sequence.pdf) ContentIssue: Air-leak noise when brake pedal is pressed. Cause: Low or high clamp load on brake servo fixings. Action: If an air-leak noise is exhibited during brake pedal depression, then slacken the 4 fixings off and re-torque to 24Nm. Ensure when torquing you follow the pattern detailed in the attachment. Re-apply the torque (following the attached pattern) a second time 30 minutes later to ensure the fixings have not relaxed. If the noise is still present then please progress with replacement of the component." Quote
