Simon_CSK Posted January 16, 2022 Posted January 16, 2022 Ok I give up!! I need to remove the sump from my Range Rover Sport TDV8's gearbox to change the ECU. I have got it dropped but cannot get it out because the tube doesn't doesn't drop low enough is there something I should know about taking it out? Quote
garrycol Posted January 17, 2022 Posted January 17, 2022 I replied to your duplicate post - here is what I said You will most likely have the original plastic sump. You will need to get a hacksaw and cut the tube which allows the sump to fall away (discard) and then purchase a ZF metal sump with removable filter which can go in (as fitted to BMWs). With the metal sump fitted you will then in future be able to replace the filter without destroying the sump. This issue and mod is well known - go onto the UK RRS or the Uk D3/4 forums and all will be revealed. Some of the metal sumps dont have a drain plug - make sure you get one with it. This is what you need https://www.ebay.co.uk/itm/372685656336?epid=1455913583&_trkparms=ispr%3D1&hash=item56c5cbd110:g:PrIAAOSw5Ohc7WVC&amdata=enc%3AAQAGAAACsPYe5NmHp%2B2JMhMi7yxGiTJkPrKr5t53CooMSQt2orsSafTQYbq3L7RBVAMi0K9cwwe4R39ypwfGLf1XZ6oAdYIHi1mrRfQvwDY5vivcq12H86mazJOdCJVHGfb7vvI%2BlfyCfSw7YK13jFp8edyZKtoEo1xCRP0lnXnBFXsI18p9Bexw7JpdFogyXz%2FVHEX4M1xiYtZ%2B33JQNRFH14KGGD6D2izLzyNKfUEq0tovA3mH%2BJDmgDaOAGkTcLnsx9IvszNiiqYb3IHr0PIpsB98%2Fdpdq6%2B%2FVj9dXhf%2BDfraTkBc4B%2FScLjXF7JsyG8j1cZbKRgntNFxOw%2BK5rWaNQGwREkXRMPPgJ9r54eUveOaeeoOV5l2n1fnhcgrHqk6%2Fpc6bzxnHRZ%2BtiGGMXkENGrJLZBw3sGlNmE%2FnNpbjOuBS%2BcUWD%2FNFX%2BAhHcXyGa%2BEljjP%2BqtvSa%2FDGHpH%2BX1dIG4imGjRrF4%2FLpUpe1lzS9lN%2Bx%2BxY3YZLtoJhewJMff%2BMohQ%2FNspmdJugD5MTIII1VFF4CH34p7bUoPptzCn3gw5J2EkGlPpCzgqPe7y558xxLBFP0w5ef%2FTSvIiLJRixpLi0jd8ERMs6eYSdUlCGWVA7qPIFx3W%2Faw1GssGHdIyuux2e%2FR7ZWh2azNcIucUpYos7odWvVGpPRlQPOdRg3oxeXDDMzcPPmKjeFkbd%2BFPjmc7GJNhKefEzCTs0mhZjb5Wyega1ItSJa7jvG5P2BchHjKAC88nxtFwcctSL0EBKl6qF7TgmckZ0td88T3WxiB5FOq6SdEayWspHtPZySRkJrKJdu4mCDqVlSZsb3ht2C983XPdjAKdhrrSl%2B7hooSxkgTg%2BFcykYbxX0Gs46zK38JxXuTG4vvzrEDAQU4C8AwVEdmzJouuTSAeDOA%2BOn3tkc%3D|clp%3A2334524|tkp%3ABFBM8vLA28xf Quote
Simon_CSK Posted January 17, 2022 Author Posted January 17, 2022 Mods can you remove this duplicate please? Quote
