Bellman Posted May 1, 2022 Posted May 1, 2022 One for the electrical mined this is on a 2001 TD5. Insert key turn on the only light is SRS start vehicle fine drivers ok just no dashboard responses at all. Any thought’s Thanks Alan Quote
simonr Posted May 1, 2022 Posted May 1, 2022 I guess you've checked all the fuses & relays are OK? I would imagine SRS is powered separately from everything else as it's the last thing you want to fail. If so, I would have a look inside the dash binacle. Try pulling apart & reconnecting the multi-way plugs. It could just be corrosion. Quote
Bellman Posted May 4, 2022 Author Posted May 4, 2022 Fixed by removing the brown/white leads of the fuse board under the steering wheel. Left of for 3 days refitted now all OK. Thank Alan Quote
bear Posted May 6, 2022 Posted May 6, 2022 Hi Alan, Was there any sign of water damage to the fuse box. It can be a problem if you have a window or leak from somewhere. Griff Quote
Bellman Posted May 7, 2022 Author Posted May 7, 2022 Hi Griff all good under the dashboard no signs of water problem must be a Land Rover thing .ha ha. thanks Alan Quote
bear Posted May 7, 2022 Posted May 7, 2022 I agree. Spent most of the day on mine!! The reason I mentioned it is it's a known cause of weired problems when water gets into the interior fuse box. Griff Quote
