Posted
I have recently changed the Turbo on one of my cars that I've had for 3 years and not done anything about.
The car is running as sweet as a nut but the exhausts are throwing out blue smoke. I suspect the smoke is as a result of the turbo failure. I have yet to road test it but have had it ticking over at 1700rpm for an hour with no difference.
What can I do to cure the smoke?
Posted
If it dumped oil into the exhaust, it will take a looong time to burn off, need to get it on the road and get it really hot.
  • Like 1
  • Thanks 1
Posted
Would taking it into my field and driving it around in low box do the same job? The car has been off the road for 3 years and doesn't have an MOT so cannot legally take it on the road unless I book an MOT in London, That would give me a drive of 400 miles lol
Posted
In all honesty running on low box won't produce that much heat, the engine isn't really working very hard due to the gearing, 10-20 minutes of cruise at 60 would normally do it, in my experience, and yes I have had it happens a few times just not from turbos :)
  • Like 1
Posted
That's certainly doable. Can get it on the road for 20 minutes easily enough.
  • 2 weeks later...
Posted
Bowie
That worked thanks. Was worried that I hadn't done something correctly. Took the car for a run and it ran fine. First run didn't get out of the village as there was a huge cloud of smoke I think other drivers were worried that my car was on fire. Second run mostly good but third run cleared everything. MOT tomorrow and suspect I may need a new wishbone.
  • Like 2
  • 1 month later...
Posted
On 5/30/2024 at 12:12 PM, Simon_CSK said:
Even better news is that it passed it's MOT so after owning the car for ovver 3 years I now have a working vehicle.
For a week and then the fuel pump failed 🤣
