Guest MJG Posted April 1, 2007 Posted April 1, 2007 As some of you know my newly aquired Series III came with a state of the art aesthetically outstanding Dash by La Salle. These are clearly exlusive as I have never ever seen one anywhere else anywhere...... B) Haven't got around to ripping it out as yet as spent this weekends 'Landy time' sorting out the misfire out. Below is a picture of the offending article in all it's resplendant glory. Those of a nervous disposition and small children should look away. Given I do not think anyone in their right mind would rip out a series III dash and fit this carbuncle my theory is (and if folks think I am talking rubbish please say so) that in a fomer life my Landy was military spec. and was never fit with a dash and this was fit to 'improve' the cab. This theory is based on Military Series III's only being fit with a basic non padded type dash. If you look at the panel the gauges/switches are in it looks as if it would reside on it's own in a basic military style dash. Or were Series III military spec Landy's fitted with the same spec dash as civvy one's ??? and thus I am talking rubbish???? Views appreciated. Quote
pugwash Posted April 1, 2007 Posted April 1, 2007 do you think it would look better if you sprayed it black? Or does it truly look dreadful? Quote
western Posted April 1, 2007 Posted April 1, 2007 All Series 3's military & civilian had the same dash, I've never seen the LaSalle version fitted in a vehicle before, maybe it's an accquired taste, it's certainly different. Quote
Mark Posted April 1, 2007 Posted April 1, 2007 Military SIII's were the same inside as civvy ones. Someone appears to have gone to a lot of trouble to fit that into there... Other ways to check your motor would be to look at the rear cross member on chassis - if it has square ends then it is ex-mil, otherwise if it tapers up towards the ends, then it is most likely civvy. The other obvious bits are the light fittings, but if someone has gone to that much effort to change the dash, it is quite possible the light fittings have been changed too... Mark Quote
Paul Humphreys Posted April 1, 2007 Posted April 1, 2007 TBH, I don't think it looks that bad But its a personal thing, if it was me I would live with it for a few months and see how it goes. You can do all the other things you have planned before you decide. Paul Quote
rtbarton Posted April 1, 2007 Posted April 1, 2007 I've taken the dash out of my SIII as I find it claustrophic. I prefer the simplicity of the SII Some pics Quote
Guest MJG Posted April 1, 2007 Posted April 1, 2007 Other ways to check your motor would be to look at the rear cross member on chassis - if it has square ends then it is ex-mil, otherwise if it tapers up towards the ends, then it is most likely civvy.Mark Now funny you should say that but I only noticed today that the rear cross member has square ends but didn't really think a lot about it. Hadn't really noticed before as the cross memenber has some rather natty 'bumperettes' fitted which cover the ends so you cant really see untill you look closely. Guess that makes it ex military then. But if they had the same padded dash as civvy ones that wouldn't explain why this replacement one had been fitted. I do like the simple look of the S11 dash too - might see if I can replicate that when I get around to ditching it. Edited to add - you are spot on Mark/Western - just found a military one the same year as mine (1975) on eBay:- http://tinyurl.com/2zlefu And the pics indeed confirm the same padded dash is fitted as fit to civvy versions. Thanks for the info. Quote
Guest MJG Posted April 1, 2007 Posted April 1, 2007 do you think it would look better if you sprayed it black? Or does it truly look dreadful? I think dreadful is an understatment - I thought about painting it but I think the problem is the bulk and size of the thing making the cabin feelling a bit 'closed in'. Quote
Dark green 90 Posted April 1, 2007 Posted April 1, 2007 I would spray it (for now) or take it out and melt it into a more interesting and appealing shape/form Quote
Hybrid_From_Hell Posted April 1, 2007 Posted April 1, 2007 That has to be the ultimate "AntiTheft" device, No self respecting pikey would nick your series, he (or she) would be the laughing stock of the caravan site if they turned up with that Nige Quote
gsr341 Posted April 2, 2007 Posted April 2, 2007 i must be the odd one out , i think it looks ''alright '' dont like the colour though , paint it black as suggested and i dont think it would look too bad , all series /defender cabs feel cramped if your over 5'3" any how Quote
streaky Posted April 2, 2007 Posted April 2, 2007 That has to be the ultimate "AntiTheft" device, No self respecting pikey would nick your series, he (or she) would be the laughing stock of the caravan site if they turned up with that Nige Quote
