bobzilla7 Posted February 23, 2008 Posted February 23, 2008 Can anyone tel me the correct order to connect the wires to the wiper motor are please? Part of the harness is missing. The wire colours are: Blue/Light green Green Red/Light green Black Brown/Light green I've attached a picture of the block on the motor to show the layout and have given them numbers. I'm pretty sure Black is the horizontal one at the top (1). My wipers have a slow speed, a fast speed, an intermittent speed and self park. Help would be much appreciated as I've blown to many fuses!!! Thanks Quote
cipx2 Posted February 23, 2008 Posted February 23, 2008 Better not use the pin layout/numbering you posted in the picture. Use the numbers on the back of the connector. Colour code in diagram as per actual colours on the diagram. Quote
bobzilla7 Posted February 24, 2008 Author Posted February 24, 2008 Better not use the pin layout/numbering you posted in the picture. Use the numbers on the back of the connector.Colour code in diagram as per actual colours on the diagram. Fantastic. Thanks. All up an running again. Quote
