k9unit Posted February 28, 2008 Posted February 28, 2008 i have a 300tdi can i adjust the tappetts or are they hydrolic. paul Quote
Les Henson Posted February 28, 2008 Posted February 28, 2008 You can adjust them in the normal way with feeler guage blades. Clearances are (inlet and exhaust) are .020 mm Adjust - No3 with No6 open .................5...........4 .................2...........7 .................8...........1 .................6...........3 .................4...........5 .................7...........2 Les. Quote
JimAttrill Posted March 3, 2008 Posted March 3, 2008 It's called the 'rule of 9', so is handy for those who count on their fingers Oh, and a tip to make it easy, put the gearbox in 5th and jack up the passenger side wheel. You can then turn the engine easily by turning the front wheel and watch the rockers at the same time. Quote
