Mikey Posted February 28, 2008 Posted February 28, 2008 I recently had to remove some fuses from my Disco 1 to check for an electrical problem, the problem was eventually solved but since then the SRS light is constantly on. Could this be caused by the fuse being disturbed or is it just a coincidence. (I notice that the relevant fuse has a yellow plastic guard over it) have I messed something up by removing/replacing the fuse? maybe the system has to be re-armed or something. Quote
Mikey Posted March 6, 2008 Author Posted March 6, 2008 Sorry to "bump" this message, just want to try it once more in case anyone can help. Cheers. Quote
sotal Posted March 7, 2008 Posted March 7, 2008 I believe even just removing the battery can trigger the srs warning light, it's one of the more annoying "features" unfortunately you can only reset the light by taking it somewhere with a computer to plug in. Once plugged in they can reset it, if it doesn't go out they can tell you what the fault is. Independent places will charge around £30, Dealers charge £50-£60 Quote
Mikey Posted March 7, 2008 Author Posted March 7, 2008 I believe even just removing the battery can trigger the srs warning light, it's one of the more annoying "features" unfortunately you can only reset the light by taking it somewhere with a computer to plug in.Once plugged in they can reset it, if it doesn't go out they can tell you what the fault is. Independent places will charge around £30, Dealers charge £50-£60 Thanks for the reply. I guess that is why the air-bag fuse has an extra cover on it. My fault for taking the fuse out. doh! Quote
Ivan Posted March 7, 2008 Posted March 7, 2008 I believe even just removing the battery can trigger the srs warning light Doesn't do it on mine. I have taken the battery off a number of times and it does not affect the SRS light. However, with the SRS it is better to take it to an independant and get it plugged in. Rgds Ivan Quote
BogMonster Posted March 7, 2008 Posted March 7, 2008 Taking the battery off doesn't automatically trigger the SRS light as Ivan said, but what sotal said is also right - once the system detects a fault, it won't automatically reset due to the SRS being a safety system, it has to be plugged into a computer. The classic mistake is to take the airbag off to centre the steering wheel after work on the steering, and then go for a drive to check wheel alignment with the bag out to save putting it back in and taking it out again. Unfortunately this trips an open circuit fault code on the air bag circuit which then needs to be plugged into a computer to reset it. No prizes for guessing how I know that... Unplugging one of the fuses will probably have set a fault code which just needs to be cleared. Quote
