zulublue Posted February 28, 2008 Posted February 28, 2008 Checked the return on Alt today and its only just over 12v so I suspect its on its way out. I have 2 Exide 900 Gell battery's linked in line, a Warn 8274 directly linked via an isolator switch, soon to have 4 KC daylighters 130w or 150w not sure yet, air compressor plus other smaller bits. 2 questions, Can I use the alternator off my 1990 3.5V8- will it fit? Do I need an 100 amp unit? I know the alt on the V8 is good, kicks back 13.8V Quote
Scotian Posted February 28, 2008 Posted February 28, 2008 I take it you mean your batteries are in parallel? Or do you have a 24 volt landrover? If you look at the alt from the V8 and it is from the same side and the holes line up then there is no reason why you cant just stick it on. I would defo do it as I dont even have a winch but all the electrics I;ve added are too much for my standard 200tdi alt Quote
zulublue Posted February 28, 2008 Author Posted February 28, 2008 it's 12V, cant remember which side it is, as I dont keep it at home. Quote
lrfarmer Posted February 28, 2008 Posted February 28, 2008 the pully may be out of line but put them side by side and you'll see as for size if you think you need a big 100amp just fit what you think Tim Quote
