SteveRK Posted March 10, 2008 Posted March 10, 2008 Few pictures of the repair/replacement so far: Piece of 2mm thick mild steel clamped to the underside of the floor ready for welding. This will then be welded to the crossmember (two small holes to be enlarged) This is the off-side: Plug welded, ground down and then 'Tetrasealed': Repeated on the other side and now with the crossmember welded in and 'Tetrasealed' all over - Lovely stuff to use Next up will be the front crossmember replacement that hopefully will follow the same method, then the arse end member Quote
