Smokin.......................on start up
Posted
Just a quick question...........I've just bought a 2001 TD5 Defender which has done 86,000 miles.
Seems to run fine and so far hasn't missed a beat (750 miles in 2 weeks).
That said I've noticed that when I start it up quite a lot of white smoke comes out of the exhaust....is this the sign of something serious or just one of those things??
Posted
if it makes you feel any better my 1989 2.5td 110 kicks out alternating clouds of black, white and blue smoke on startup, sometimes so bad you cant see behind you... :ph34r: might be summat to do with the veg oil.... :blink::unsure:;)
Posted
Try testing the heater (glow) plugs , it may be time to put new ones in.
Good thinking I'll check when they were last replaced (it's got fsh) what sort of mileage should glow plugs last??
Posted
First check the glow plugs. If the problem persists, get a compression check done. White smoke on startup is normally caused by low compression, but don't get worried until you have tried the glows.
Posted
:blink: The last time mine td5110 99 mod started coughing white smoke, I had to think twice. And guess what!! :ph34r: I had filled it up with Petrol!! :unsure: Done that lately? Petrol in Diesel tank? :o
Posted
I don't get white smoke... but a few black puffs.
If I then rev the engine to 1400ish I get plumes of blue smoke sometimes - and I've given up finding out what that is!
Posted
Dont use the throttle when starting ??
Posted
an update (for those that care) :cry:
A friend who owns a garage has had the TD5 in and checked the glow plug and they all look ok, as we're out to the Alps soon I asked him to give it a good service ready for the winter......
As he started we had a peek in the water header tank thing (sorry I'm not technically minded at all) and we found it full of a oil:water mix......more oil than water :cry: :cry: head gasket??????
So how many hours does it take for a good mechanic to change a head gasket and is there anything else I should get him to do at the same time??
Posted
Its not something you should be getting the garage to rush. Changing the head gasket is a few hours work. The thing you need to know is what caused it and what other damage has been done.
If the head needs skimmed then its a machine shop job which will cause further delays.
Posted
Agreed that I won't be getting them to rush it....I'm going back to France without the Defender and will come back when it's ready....as to cause what are the possible causes (or are they too numerous to list).....the mileage is 86,000??
Posted
Before you whip the head off, check that the oil cooler hasn't got an o-ring gone or even corroded through. The oil pressure at 4 bar is higher than the coolant pressure so pushes the oil into the coolant.
  • 3 weeks later...
Posted
the head is off and it's cracked in one of the exhaust ports...so where's the best place to buy a replacement head from and how much shoudl I be paying??
Posted
Over here we are too poor to buy new cylinder heads so we get them welded. Costs about £100 including taking out and replacing the valve seat.
