rodp Posted July 21, 2008 Posted July 21, 2008 Hi All, been a long time since I was last on here and as you may guess, I need help. My 110 has a Disco front axle, late one with black teflon swivels. Outer splines have gone and are spinning in the driveplate (getting about slowly on diff lock) Does anyone know the part numbers and description for the required part, do I need all the shaft or does the outer come off the inner (I haven't had one apart for getting on 10 years now) Is 110, Disco, classic the same part so long as 24 spline? Any help appreciated as I need to order one on the web. Oh, it's near side (left hand) Rod Quote
western Posted July 21, 2008 Posted July 21, 2008 outer part with the 5 bolts securing it is a drive member -- FTC859 same as a defender. Quote
rodp Posted July 21, 2008 Author Posted July 21, 2008 outer part with the 5 bolts securing it is a drive member -- FTC859 same as a defender. It's the shaft itself that's the problem, I have some drive plates. Rod Quote
western Posted July 21, 2008 Posted July 21, 2008 24 spline shaft which includes the CV joints are LH FTC3147 RH FTC3146 Quote
rodp Posted July 21, 2008 Author Posted July 21, 2008 24 spline shaft which includes the CV joints are LH FTC3147 RH FTC3146 Many thanks, that's the bit I need. Rod Quote
