bishbosh Posted July 28, 2008 Posted July 28, 2008 I have two wires I need to identify. I think they are diff lock warning light and reversing light. One wire is green, the other is green with brown or brown with green . Both have female spade type connectors on the end (originals) So which is which? 1989 90 CSW. Thanks, Bish. Quote
western Posted July 28, 2008 Posted July 28, 2008 Green/Brown trace is reverse lights wiring. Green is a power feed ignition controlled. difflock switch only has one power wire the other is earth & attached with a ring terminal to the difflock housing forward inner bolt reverse light switch uses 2 x spade terminals. Quote
bishbosh Posted July 28, 2008 Author Posted July 28, 2008 Now I am confused! These are two separate feeds, each with one wire as described and with an original femal spade connector (long plastic type housing). So ar you saying I should have more wires somewhere? They may well be there, just haven't looked closely yet.....!! Quote
western Posted July 28, 2008 Posted July 28, 2008 difflock has 2 wires 1 is the power in & other a earth reverse light switch also has 2 wires 1 is power in other goes out to revesre lights,it's earthed by it's body to the gearbox, see photo below,the 2 wires nearest right hand side of photo. Quote
western Posted July 28, 2008 Posted July 28, 2008 Correction to my earlier reply. Difflock switch 2 wires Black/Blue trace & Earth - Black. tried to get a photo of my difflock switch wires,but it's raining hard & can't get my camera in the right place to take a decent photo. Quote
lansalot Posted August 2, 2008 Posted August 2, 2008 Apologies for the crappy/shaky camera-phone shot: Diff lock sensor circled: Quote
