Posted
Does anyone know where I can get inner sills for a defender the ones that connect from the bulkhead to the tub, or are they just called something else and Im missing them? cheers all that are wise!
Posted
OK, Ralph (Western) on here is your man to get a part no. and with that you can find suppliers. Though if I understand it right these used to be galv'd on earlier models so you may do better to look for a s/h set rather than buy new.
Posted
part no.s were MWC1086 O/S and MWC1087 N/S when i did mine last year and they came Galv.
Posted
You have proven yourself wise OH mighty Early90! well done, and thanks....
Get the brackets that attatch the sill to the `b`post ,if the sills are rotten then they probably are aswell........ part no 347436 same both sides...only a couple of quid each and worth it if only to not have to bother removing the old ones from the old sills. Have some cage nuts (m6 i think) x4 to fix brackets to b post.
