jim109 Posted October 14, 2008 Posted October 14, 2008 Hi, I have a problem with my series 3. The clutch when depressed, is allowing you to selected a gear but when you lift the peddle nothing happens. The clutch worked perfectly before I carried-out major welding work on the chassis, a year ago and has been sat in the shed since. Is this a seezed thrust bearing and if so can I free it easily?. Cheers. Quote
