djbrookes Posted January 13, 2009 Posted January 13, 2009 Hi lads, Please could someone possibly tell me if I will be able to wire up a rev counter to my 200tdi in my defender. The engine is originally from a 93 disco which obviously had the rev counter so I assume it must be possible? The engine has had a new alternator about 2 month ago, the replacement did seem slightly different to the original but was told that the original was superceded by the new unit. But surely it must have the same connectors otherwise how would it work in a disco ? I'm waffling.... Please could somebody advise? Cheers Josh Quote
FridgeFreezer Posted January 14, 2009 Posted January 14, 2009 White/black wire* to the W terminal on the alternator. * = You'll need to check this against a wiring diagram for your application. Quote
