bushwhacker Posted January 20, 2009 Posted January 20, 2009 Advise needed, I have the head off a 2.5 n a d and when I had a look at the piston tops I have noticed what looks like a single hair line crack in all four pistons running from the the combustion V point to the top edge of the four pistons. Each crack is almost in the same place on each piston. I know it will not be easy for someone to tell me the extent of the cracks, but has anyone seen this happen before and would it be ok to build the engine back up and hope for the best running wise? Can the pistons be taken out by not removing the engine? I do welcome advise and realise it is up to me if I act on it. Should have mentioned the engine had been over heated Quote
Lars L Posted January 20, 2009 Posted January 20, 2009 By crawling underneath and removing the oil pan, you must be able to take your slugs out. Quote
Les Henson Posted January 20, 2009 Posted January 20, 2009 You can drop the sump, undo the big end cap nuts, remove the caps and then push the piston/conrod out the top of the bores. T/D engines have a habit of cracking, but not N/A. The cracks will eventually get bigger, so it's best to replace them sooner, rather than later. There's no way of knowing how long they will last. New piston kits are about £40 each. Les. Quote
bushwhacker Posted January 21, 2009 Author Posted January 21, 2009 Thanks again guys. I am not too sure what I will do. I have four used spare pistons from another engine with rings on them. The bores they came out of looked pretty good and the side walls on the pistons look ok. I will clean these up and check them further. I know new piston kits are only £40, but times 4 it is a not a good time. As we all know. If anyone reading this thinks it is a bad practise to stick second hand pistons in would you please advise. Quote
Les Henson Posted January 21, 2009 Posted January 21, 2009 It's a bad idea , but if you're not that fussy about the engine, then bung them in. Make sure they are the same size as the old ones though. Les. Quote
bushwhacker Posted January 21, 2009 Author Posted January 21, 2009 I think I will give the second hand pistons a go and when things pick up I want to go for a 200tdi engine. Hopefully the n a d will last that long. Maybe even a galvanised chassis. Now where would I get a printing press, ink and paper the size of £100 zzzzzzzzzzzz Quote
