Posted
My nice new water temperature gauge from SPA_UK
www.SPA_UK.co.uk
The warning light in tha gauge comes on when the temperature reachest 105 dec C
The LED warning light to the left of the rev counter is to tell me that the radiator fan has come on!!!
Posted
did u deliberately bolt it in wonkey?
I take it MMG has done it so the normal-running needle position will be at the 12 O'Clock position
Posted
I normally set my gauges so that the needly is at 12 O'clock.That way you KNOW that the needle has moved.No need for a position pointer.
I eat rat poison
mike
I can cause trouble in an empty house.
Posted
I thought that but wouldn't the "park brake" lamp be lit?
The park brake light is on.
Vehicle stationary ticking over at 600/700rpm.
Engine still cold as it's just been started.
You can't see the park brake light brecause it's hidden by the steering wheel center.It's to the left of that warning light and on the bottom row of warning lights.
I eat rat poison
mike
I can cause trouble in an empty house !!!
Posted
The written 'PARK BRAKE' light isn't used/connected on UK vehicles it's for Australian market vehicles, but mines connected to the other one thats lower down.
Posted
So you do 60mph and 3000rpm then ;)
Posted
Where did you get your rev counter from ?
If I remember it came from Lowtension Ltd.
I can't find the invoice so I'll check elswhere later.
I eat rat poison.They didn't increase my doseage yesterday
mike
Posted
Good racers practice.
By that standard, on an LR you should adjust the petrol gauge so that it's at 12 o'clock on the red, "Normal Position" :lol::(
Posted
I got it from..........
Lowtension Ltd
Tame Valley Business Park
Magnus
Tame Valley Industrial Estate.
Tamworth
B77 5BY
01827 250004
www.lowtension.com
www.vdoinstruments.com
www.boatgauges.com
www.bathroomspeakers.com
HTH
I eat rat poison.They didn't change my dosage yesterday.
mike
Posted (edited)
Excellent, thanks :D
this is how mine is connected
I used this one genuine LR AMR5724 as fitted to V8 50th & heritage Defenders connected thus
----------------rev counter terminals marked 2 ---> 'W' terminal on 100amp Marelli alternator
+ve ---> ignition controlled feed
-ve ---> to earth/ground [any earth cable behind instrument pack]
gauge lighting to existing gauges lighting = red/white tracer
set 3 slide switches -- I adjusted the slides 1 & 3 up with 2 down, to give approx 4000rpm max & 800rpm at idle
:D :D
Edited by western
Posted
Funny thing is Ralph.
That rev counter of mine has a Land Rover sticker on the back !!!
mike
Posted
Mine cae from Croytech, they're at the shows etc. IIRC it was £55 so cheaper than Lowtension. Same part, VDO gauge etc. When you connect it, don't try to get a signal out of the alternator mounting bolt!
Posted
ROFL at that!!
Mine cost me £54.99 including postage, November 2004 !!!
I eat rat poison.They didn't change my dosage yesterday !!!
mike
