200tdi in a series warming up!!!!
Posted
hi all does any1 know how long from cold start it should take the water in the header tank to start feeling warm????
also i want to bend my exhaust down and round so it will come out just under the drivers door,any1 know of any ways to do this i thought mayb steel flexi but unsure where to obtain this,would i need a cat and should i put my back box on would this silence it,or can it be a straight through pipe??????????????????????
Posted
It can take quite a while for the water in the header tank to get warm - 20 minutes or so. Flexible exhaust tubing should be available from most motor factors/exhaust suppliers. You don't need a cat. If you have no silencers at all, then the exhaust noise might be excessive at higher revs - although the turbo cuts the noise down quite a bit. Fitting just the rear resonator off a 200/300 TDi is what a lot of people do.
Les.
