white90 Posted November 1, 2009 Posted November 1, 2009 Will they be able to reuse the fittings from the new pipes I ordered but made to fit or will it be all brand new? I'm thinking an Agricultural specialists may be able to help get one sorted?
Cartman Posted November 1, 2009 Posted November 1, 2009 Pirtek or suitable hydraulic hose specialists should be able to swage them on for you
lrfarmer Posted November 1, 2009 Posted November 1, 2009 tractor place would make you up a new pipe but it would be all flexy someone like Pirtek should be able to make a steel pipe with flexy were needed jimmy price in tiverton helped me when i did my power steering pipe useing the old steel and a union on to make a new flexy fit
ejparrott Posted November 1, 2009 Posted November 1, 2009 Will they be able to reuse the fittings from the new pipes I ordered but made to fit or will it be all brand new? I'm thinking an Agricultural specialists may be able to help get one sorted? Fittings in good useable condition should be capable of being fitted to new hoses no problem. The law now says though, that hoses themselves cannot be re-terminated. As a result, you may find some companies are unwilling to use old components. There should not be a problem in getting new fittings the same. We had some made at work recently, including a 1950's odd french fitting. They'll find them new, dont worry.
redben101 Posted November 1, 2009 Posted November 1, 2009 Tony, I had two new oil hoses made up by http://www.hoseandhydraulicsgroup.co.uk/ who are in Taunton. They were very helpful and made the hoses up using the old fittings on the oil filter end along with the part of the rigid steel pipework before terminating in flexible hoses.
Bowie69 Posted November 1, 2009 Posted November 1, 2009 Tony, Try Mayflower Hydraulics in Bridgwater, they seem to be OK, quite old school in a nice way, especially the folding type of transactions
FridgeFreezer Posted November 2, 2009 Posted November 2, 2009 There is a big sign in HypHose about re-ending hose or re-using fittings (apart from those specifically designed to be undone & re-made) the gist of it being "No, so don't ask". There is also a picture of what's left of someone's arm/hand that was near a hose when it failed. Even badly photocopied black & white it's enough to put you off your lunch. As has been said, there's pretty much nothing they won't be able to match the thread for, last set of PAS hoses I had made cost £25 all in brand new, so why prat about?
Eightpot Posted November 2, 2009 Posted November 2, 2009 when I did my oil cooler pipes I cut the fittings out of some old pipes, bought a couple of metres of hose from pirtek and a few of the crimp on collars - didn't cost much, and has been absolutely fine - the pressure is fairly low in the cooler pipes.
white90 Posted November 2, 2009 Author Posted November 2, 2009 Fridge I am not Pratting about I just don't want to get there and they say o no we don't have those fittings , if you had brought yours along we could have used them. This isn't hydraulic pressure it is oil pressure. Thanks for you words of advice otherwise. Thread closed now I have some ideas And yes I could call them but what do I describe the sodding fittings I have to see if they stock them... as was suggested and subsequently deleted by me.
white90 Posted November 4, 2009 Author Posted November 4, 2009 Finally sorted ESR3691 superseded by pbp101140 that has been superseded by pbp500200 hydraulic suppliers could not make the type required.
