Posted
straight 30 non detergent.
I've heard someone uses EP80-90 and even ATF
but the Warn recommended is SAE30
I got 5l from Mole Valley Farmers
it only needs 6 fl/ounces [uS, liquid] = 0.312 252 821 pint [uK]
a standard Tea mug is the correct amount
don't overfill as it Will leak
Posted
it only needs 6fl/oz which it approx 1/2 a pint
Erm don't wanna start arguement but 20fl/oz is 1 pint so 6 is just over 1/4 pint
Posted
Not in the USofA. They have different size measurements to us.
Chris
Posted
But we is all in this country where 20fl/oz is 1 pint
mind you America has 5/4 measurements in wood
Posted
Perhaps that is why Tony said "it only needs 6 fl/ounces [uS, liquid] = 0.312 252 821 pint [uK]"
I sound like I am having a go, sorry. ;)
Chris
Posted
But the Winch is American as is the instruction booklet :P
Mark
Phil at PG winches uses EP90 IIRC he knows what he is doing
the manual says SAE30 so that's what I always use.
5lt (UK) goes a long way
I've rebuilt a few and still have loads left.
Posted
I did speak to a couple of grown-ups about what oil to use, and they recomended using ep90, so I will continue to do so. :) Thanks for confirming.
Cheers
Mark
Posted
IMHO :P , a low viscosity gear oil should be the best choice.
I think they have specified 30 weight as they want a low enough viscosity for decent low temperature flow so as to avoid power consumption and allow the oil to climb up the gears to the upper ones. They have avoided multi-visocsity, detergent engine oil since the additives are not the best for gear use.
Back in the day, there was no such thing as a low visocsity gear luibricant, so engine oil was specified. Since today, a variety of these lubes exist, it makes better sense in this application. I am using Redline MTL.
