Edd Posted May 27, 2006 Posted May 27, 2006 I managed to drop the small banjo bolt that is on the back of the injector pump on a 200tdi. (it is for the pipe conecting to the turbo) i have checked on the parts manual but its not listed. anyone know where to get one or just the size and threads would do. Cheers. Edd Quote
western Posted May 27, 2006 Posted May 27, 2006 The spill return banjo might be the same size LR part number STC3297 or ERR1125 banjo bolt for the turbo oil feed pipe, otherwise a visit to your nearest diesel injection specialist [should be listed in the phone book/yellow pages] to get a replacement. Quote
Phil Hancock Posted May 28, 2006 Posted May 28, 2006 ERR886 bolt boost capsule, on the injector pump page. Quote
western Posted May 28, 2006 Posted May 28, 2006 Phil, where did you find that number ?? it's not listed as a seperate part in EPC or Microcat Edd, where did the escaped part run off to? I reckon you can retreive it from it's hiding place or has it gone down a drain???? Quote
JST Posted May 28, 2006 Posted May 28, 2006 Edd - i recently did a similar thing jsut go to the nearest FIP specailiast they will have one to fit and prob less than £1!!! Quote
Edd Posted May 28, 2006 Author Posted May 28, 2006 Edd, where did the escaped part run off to? I reckon you can retreive it from it's hiding place or has it gone down a drain???? well it probably fell on the floor when i was checking the engine prior to fitting. But... The workshops been compleatly rearanged the 110 moved out an and other motors moved so its probably quicker for me to go and get one tham turnm the workshop over trying to find it... I am shure my parts book doesnt have that number listed. on the injector pump page all the other bolts are listed but not this one?? Anyway Cheers Edd Quote
Phil Hancock Posted May 28, 2006 Posted May 28, 2006 Phil, where did you find that number ??it's not listed as a seperate part in EPC or Microcat Disco parts disc & 110 parts book page 194. Quote
western Posted May 28, 2006 Posted May 28, 2006 Disco parts disc & 110 parts book page 194. Hmmm have to check my 110 paper parts cat. when I'm back home tomorrow Which parts disk have you got ?? Quote
western Posted May 28, 2006 Posted May 28, 2006 well it probably fell on the floor when i was checking the engine prior to fitting. But... The workshops been compleatly rearanged the 110 moved out an and other motors moved so its probably quicker for me to go and get one tham turnm the workshop over trying to find it... Edd Did you sweep the floor before moving the contents around ? or maybe it's sat on the chassis rail or engine mount at you & hiding Quote
