Off Road Toad Posted October 5, 2010 Posted October 5, 2010 Right then - i have a very annoying problem. My wipers on the 90" are not performing as per specification. It started about a year and a half ago when i could'nt turn my wipers off. I have replaced (at that time) the park sensor and the switch assembly - these made no difference. I resorted to pulling the fuse when i didn't need wipers . After a while they seemed to just fix themselves . Until now that is. When we were in Romania in july at a car wash, i pulled away and couldn't turn them off again. When the car arrived back in the UK (trailered back) they worked fine. Now they wiping full time again and i'm getting peeved now. Any ideas? I've heard there is a delay ECU somewhere? is this correct and where will i find the bugger? Any thoughts or suggestions welcome before i smash it to peaces with Landrover tool no:1 Steve Forgot to mention its a 1998 300tdi (well originally it was ) Quote
western Posted October 5, 2010 Posted October 5, 2010 delay/intermittent relay is the Red one behind the fusebox metal panel, sounds like it's not operating correctly. looks like this Quote
Off Road Toad Posted October 5, 2010 Author Posted October 5, 2010 Superb - i'll try swapping it out with known good one before purchase, no doubt it's uber£££££ Thankyou. Steve Quote
western Posted October 5, 2010 Posted October 5, 2010 Superb - i'll try swapping it out with known good one before purchase, no doubt it's uber£££££ Thankyou. Steve price here, as a example Quote
cackshifter Posted October 5, 2010 Posted October 5, 2010 Or you can push the boat out and get an upgraded one with a programmable intermittent delay. Can't remember the no. it's the Golf GTi one, cost me just over £10. Ahh.. found a link with the pat no.s herelink AFAIK it just plugs in, but there's a thread on here about it. Nigel Quote
Retroanaconda Posted October 5, 2010 Posted October 5, 2010 How do you control the delay? Fit a new stalk with a control for it? Or some sort of rotary control in the dash? Quote
WarPig Posted October 5, 2010 Posted October 5, 2010 I bought one of these relays, but it didnt work in my 300tdi. It just put the wipers on permenantly. With the correct relay, to adjust the intermitent wiper to give say a 5 second delay, flick your lever to intermitent, then back to off. Count five seconds an then switch it back to intermitent. Done. If anyone can point me to the correct relay, I would be very grateful Quote
cackshifter Posted October 5, 2010 Posted October 5, 2010 Interesting it didn't work on a 300- my relay's gathering dust & high on the todo list to fit. Pt nos are on link on my prev post. Brakes and a BP style oil leak are occupying a bit of time first... Nigel Quote
Aragorn Posted October 6, 2010 Posted October 6, 2010 I used a Golf "99" on my old vauxhall, and on the old A4, and they worked fine. I guess if the landrover wirings a bit different you might need to move some pins around to sort it. Quote
Off Road Toad Posted October 6, 2010 Author Posted October 6, 2010 Pulled the relay out and It came as no surprise that its full of water Don't know how that happened Steve Quote
WarPig Posted October 6, 2010 Posted October 6, 2010 When I switched the wipers on they worked fine, but I couldnt switch them off. They just remined on at the slow speed. Had to remove the relay to stop them. Bit annoying as I really wanted to have adjustable intermitent wipers. Aragorn, which pins should I try rearranging, and how, please? Quote
wormey Posted October 6, 2010 Posted October 6, 2010 I had this problem, tried everything but failed. I had to call a auto electrian. it's the earth that was the problem. they ran a new earth lead from the washer pump, all sorted. Quote
WarPig Posted October 6, 2010 Posted October 6, 2010 It was only when I fitted the new relay that I suffered the problem. As soon as I put the original relay back in, everything was fine again. Quote
western Posted October 6, 2010 Posted October 6, 2010 How do you control the delay? Fit a new stalk with a control for it? Or some sort of rotary control in the dash? updated my '89 110 to the later intermittent front wash/wipe http://forums.lr4x4.com/index.php?showtopic=927 Quote
Retroanaconda Posted October 7, 2010 Posted October 7, 2010 Mine both have that as standard, but my Focus had a twisty bit on the stalk where you could actually adjust the time delay between wipes on intermittent mode. Since it always happens to be raining just the wrong amount to suit the Defender's pre-set delay, it would be handy to have it adjustable. Quote
TSD Posted October 12, 2010 Posted October 12, 2010 Just fitted a VW '99' relay to the Ibex (300tdi loom). Works a treat, best upgrade I've found for ages As a side benefit I found the number of wipes you get when washing depends on how long you hold the wash button down for. A brief squirt gets only one wipe, holding it down longer seems to give 2 3 or 4 wipes after you let go. Quote
WarPig Posted October 12, 2010 Posted October 12, 2010 TSD, where did you buy your relay from please? Quote
TSD Posted October 12, 2010 Posted October 12, 2010 TSD, where did you buy your relay from please? From these guys via eblag. Maybe not the cheapest on the bay, but the postage price was honest (extra items free). Relays were clean, unmarked and arrived next day. Going to upgrade my 90 at the weekend with the second one I bought Quote
Aragorn Posted October 12, 2010 Posted October 12, 2010 One of mine came from a skoda, and was numbered differently, and as a result cost me 3quid delivered. Let me see if i can find the part number for you. 3B0955531 numbered as "197" Quote
PieEater3142 Posted March 7, 2012 Posted March 7, 2012 Does anyone know if there is a low profile version of this relay? I have fitted a new fuse box and this bugger wont clear the lid.... Quote
western Posted March 7, 2012 Posted March 7, 2012 it's meant to fit on the metal plate front face nearest to the bulkhead on the lower row of relay prongs so it sits alongside the other relays. there isn't another low profile version for defenders. Quote
PieEater3142 Posted March 8, 2012 Posted March 8, 2012 Yer I had a dig around. Looks like I'm making a custom cover for the fuse box (as seen here): It sits on the far left with the flasher relay. Just gonna have to knock something up to go over it all. Don't really want wood but metal is gonna be dodgy - anyone got a plastic moulding tool Quote
