Phil Posted October 8, 2010 Posted October 8, 2010 Help, please, with part numbers for the following to fit my 2002 110 CSW: Front right brake caliper Front left brake caliper Front brake disc Rear right brake caliper Rear left brake caliper Rear brake disc Guess what next week's job is! Thanks, Phil. Quote
western Posted October 8, 2010 Posted October 8, 2010 front calipers for solid disc are LH RTC5573 & RH RTC5572 front solid brake disc FRC7329 rear disc non abs SDB000330 rear calipers LH STC1268 & RH STC1269 What's wrong with the existing disc & calipers, you could rebuild the calipers using stainless steel pistons & new seals, a tad cheaper than buying brand new. Quote
Phil Posted October 8, 2010 Author Posted October 8, 2010 Thanks, Ralph, the precision of your reply made me go and check and I find the (factory fitted) front discs on my vehicle are vented. Can you find the part numbers for these discs, and perhaps the calipers for them too? The reason for replacing the calipers is that I simply can't have the vehicle off the road for the time I'd need to refurbish them. I hope not to have to replace the discs but want to make sure I have the part numbers in case I have to. Thanks for your help! Phil. Quote
western Posted October 8, 2010 Posted October 8, 2010 calipers for front vented disc brakes are LH STC1267 RH STC1266 Quote
