chris_oakley Posted October 9, 2010 Posted October 9, 2010 Symtoms - Hard Start from Cold, Excessive smoke diesel smelling, and sounding like its misfiring rough. fuel supply is fresh, cracked of the injectors. all make a noticeable difference in engine sounding, apart from one that makes no difference in the sounding at all. Next step is to change the injector to a different cylinder to see if the results are the same as above. What are peoples thoughts.? Injector Fault? or worse.. Quote
chris_oakley Posted October 9, 2010 Author Posted October 9, 2010 But it doesn't improve when warm , glow plugs are only operating for a time amount anyway , are they not ? Quote
Retroanaconda Posted October 9, 2010 Posted October 9, 2010 I think you may have identified the cause yourself, the injector you mentioned. Complete your test and see what happens Quote
western Posted October 9, 2010 Posted October 9, 2010 a poor injector will definily affect the running/starting, check the items marked in the fails to start & engine misfires columns on the attached diesel fault chart. diesel fault diagnosis chart.pdf Quote
chris_oakley Posted October 9, 2010 Author Posted October 9, 2010 Everything points to the injector gonna go to workshop now. bored so got nothing to loose. will post back later. Quote
chris_oakley Posted October 9, 2010 Author Posted October 9, 2010 Just checked it out , swapped number 3 inj with number 2 inj. Fault still lies with Number 3 cylinder. area Quote
gee1599 Posted October 9, 2010 Posted October 9, 2010 i would take the rocker cover off and check the rockers on cyl 3 next also when you cracked of the injectors was fuel coming out of number 3 injector pipe?? Quote
chris_oakley Posted October 9, 2010 Author Posted October 9, 2010 YES fuel was coming out of number 3 but. it seemed not as high pressure as all the others although il double check this 2morow. i don't think its base engine related. more fuel related. Quote
Retroanaconda Posted October 10, 2010 Posted October 10, 2010 Then it may be the injection pump's no. 3 feed? Quote
