Turn (signal) lights and hazard light don't work
Posted
Hello. My TD5 which drowned last year was up and running after I finally replaced my ECU a second time. I have been using it for about 9 months now. Last month the turn lights and the the hazard lights went out. After a couple of days the hazard light came on for a few seconds then died out again. It's been a month since.
I read somewhere that the hazard lights are connected to a relay. If so, it might be the relay but I can't seem to find it's location.
Of course it could also be the hazard switch. But because of my car's flooding it could be grounded wires.
Can anyone offer a suggestion which repair I should try first?
Thanks,
Tony
Posted
The signaling lights are controlled by 2 relays. they are in the fuse box under the steering wheel. More information would help to better direct you.
1) Do the signal light turn on even for a short while?
2) Do you here a click from the in cab fuse box?
Please describe the symptoms.
Alon
I had a similar problem only one side worked.
Posted
Thank you all for the tips and the links.
Today I worked on my Turn indicator lights.
I connected the purple supply terminal to the left and right indicator terminals and as described the left or right indicator lights stayed on without flashing.
I tried to connect purple terminal to white with green trace flasher terminal and nothing happened.
Am I supposed to attach purple terminal to left or right terminals at the same time as the purple to flasher terminal?
Can I rule out hazard switch as being defective?
Thanks everyone.
