Posted
I got a second hand Defender 90 (1999)
The primary remote operates well and disables the alarm and immobilizer correctly.
I decided to change the remote battery on both remotes. For the primary unit, I changed the battery according to the procedure and it’s fine.
However the spare key remote is not working (the old battery was completely dead: did not work before the battery change).
I followed the normal procedure with no success.
I also followed this procedure:
1: Enter the L322 and close doors
2: Insert key in ignition lock. Turn to Pos II, then back again and remove key all in a sequence without delays
3: Keep the Unlock button of the remote pressed. Do not release it.
4: Still keeping the unlock button pressed, now press THREE TIMES on the bigger LOCK button.
5: Now release the UNLOCK button. L322 confirms by locking doors.
6: Put the key back in the ignition lock, turn to Pos II, turn back and remove key, all in a sequence.
... still nothing.
Does anyone know another procedure?
I have the 4 digit security code (EKA) and I also have the primary key remote that works.
Thank you.
