Dorsetfreelander Posted December 5, 2012 Posted December 5, 2012 Just had the Freelander 2 serviced and noticed the attached in the footwell below the glovebox. Haven't been back to the garage yet (it's a long way to go). Glovebox now drops down so it's some sort of damper and I think that a bit has broken off the end. Any suggestions welcome. Thanks it's got 6H52-F06066 and LandRover logo printed on it Quote
swerving Posted December 5, 2012 Posted December 5, 2012 6H52 **** googles as a front bumper See http://www.ebay.co.u...A-/300512890250 Some part of the fitting system? Excuse my ignorance but perhaps the 6H52 relates to a model no. for the FL2 I'll shut up and sit in the corner! Quote
defv890 Posted December 7, 2012 Posted December 7, 2012 Hi That's the damper for the glove box so it opens Slowly Looks broken to me One end with the rod and clip fits on the back of the glove box and the other end clips into a hole in the dash Hope this helps If its like this since the garage ring them up and ask for a new one Quote
western Posted December 7, 2012 Posted December 7, 2012 GLOVE BOX DAMPER ASSY FL2 click this http://www.brit-car....hp?xProd=152172 Quote
Andy_Jeff Posted December 30, 2013 Posted December 30, 2013 Unbelievably, almost a year to the day, I had my FL2 serviced and the same item appeared in the passenger footwell. I called the dealer and explained the problem and they said "Nothing to do with us mate!", until I reminded them that they had changed the pollen filter behind the glove box. "oh dear, ah yes" said the man, "Bring it in and we'll fix it!". Maybe it's something easily damaged when changing the pollen filter! Andy. Quote
Dorsetfreelander Posted December 30, 2013 Author Posted December 30, 2013 Mine had the fixing broken at the end , I fixed easily it with a cable tie rather than drive to the garage. It's been OK since. This has been the least of my Freelander 2 problems this year (new clutch, throttle body, seized handbrake mechanism, replace steering fluid reservoir, howling noise from turbo and now drive shaft going wobbly) oh nearly forgot - rear passenger door not locking properly. My son works in Africa and says that you don't see Landrovers any more, everyone drives Toyotas. Quote
Stooby2 Posted December 30, 2013 Posted December 30, 2013 It's always been the saying in Australia that "if you want to go into the outback, take a Land Rover. If you want to come back, take a Land Cruiser." I've never known why, apart from a brief period from about 1992-1998, Land Rover can't make a reliable vehicle that isn't plagued with design faults. Quote
missingsid Posted December 30, 2013 Posted December 30, 2013 From the link above it has been superseded with a new part that has a hinge in it. Perhaps the original part was poorly designed at the outset and is easily broken. Poor performance of the garages for not replacing it when they broke it. Quote
