Posted
Has anyone every seen or built a stainless steel bulkhead?
What type of steel is a bulkhead made from?
Cheers,
Mike
Posted
That looks nicely done. I like the web sites motto "The ONLY place for a coil spring is up Zebedee's arse" Although taking over the nürburgring with Defenders might be a good idea.
  • 5 weeks later...
Posted
Can you use stainless welding wire? That would stop the weld rusting, but there would still be a bimetallic joint so it would go eventually.
Thinking aloud here......
Eric
Posted
It bears saying that stainless and ally/galv don't play we'll together. If you plan on having many galvy bits anywhere near the bulkhead/foot wells then you may in the long run be better off going the galv route. For instance, the stainless bolts in my mate's truck went through various bits of ally and galv, and after barely two years, it was nigh-on impossible to undo them, and there was corrosion around any ally that they touched. You can get a gunk that stops this, I think it's called galvanic inhibitor compound or some such, they use it in the marine industry for exactly this.
Hope that doesn't just cloudy things up!
Jake
