Posted (edited)
I know there are some Swedes here, so I thought I'd ask here :)
In a few weeks (probably leaving the 17th or so), I plan on going to visit a friend in southern Sweden again. Last time I did it was in summer, so no problems there. I'll be in the Malmo/Lund area, and maybe go up as far as Helsingborg, so nothing too silly. As far as I hear it's raining there atm, so I don't think I'll have to worry about meters of snow :(
So I'm wondering about the legal requirements, both in Sweden and on the way there (Germany, Denmark). Do I have to have winter tyres, do I need to bring chains, ...?
AFAIK Germany = You want winter tyres when in an accident, but apart from that you're not legally required to have it, especially in a 4x4. Is this (still) correct?
As for Denmark, I'm not sure if I'll be taking the bridge or the ferry this time, the bridge was nice but does add quite a bit to the travel time.
I'll be taking my P38, it's currently on 265/75R16 BF ATs, sadly a size that doesn't have the crystal-in-a-mountain logo :(
Oh, and how's the LPG availability? I could live with driving on petrol while I'm there, but still, it would be nice to do it on LPG ^_^
Thanks!
Edit: LPG stations I've answered myself, this is a brilliant site, even has POIs:
http://www.mylpg.eu/stations/sweden
Looks like there's one in Malmo, perfect.
Edited by elbekko
Posted
Yes you need legal snow tires, not all AT or Snow & Mud tires are legal, they must have the snowflake symbol on them.
Yupp rain at the moment and no snow in the forecast for the next week.
Todd.
Posted
Hmm, that's annoying. Is this something they'll actually check when you get stopped, or just something they can use against you when you get in an accident, like in Germany?
I don't really feel like buying a set of winter tyres for a two week trip where I most likely won't even need them...
Fridge, that's definitely worth a try :hysterical:
Just got linked this, looks like M+S is sufficient? Or is this outdated?
http://www.europcar.com/EBE/module/render/Driving-abroad-in-Winter-conditions
Posted
Outdated I believe... Proper winter tyres should have the snowflake/mountain symbol on the side, M+S is not OK since lots of US made tyres have this marking even if they are normal summer tyres.
Read: http://www.transportstyrelsen.se/en/road/Vehicles/winter-tyres/
The link you provided seems to state otherwise:
"Winter tyres are produced specifically for winter driving and are labelled M+S (M.S, M-S, M&S or Mud and Snow)."
So Ben should be legal with his BFG ATs.
Posted
Escape,
You can NOT avoid the fact that the tires must have the snowflake symbol to be legal, no matter the tire classification.
Todd.
Posted
Todd,
I agree that you can only identify a real wintertire by the snowflake symbol. However, we are not discussing wintertires here, only the legal requirements. And as we all know, those are often far removed from any logic whatsoever (we have plenty of examples here in bhellgium...).
All the documents I (and Ben) can find regarding what type of tires are required in winter in Sweden seem to use the M+S as a reference.
Filip
Escape,
Todd.
Posted
Hello Mr Slow
Here in Denmark it is only recommended to use winter tires not a requirement but if you do it must be on 4 wheels and regardless to tyre there must be at least 1,6mm tread
Re Lpg. there is hardly any stations if any at all.
Have a nice trip
Kind regards
Ole.
Posted
Everything on that link says M+S is sufficient, which I do have.
It's just that this size/speed rating isn't fully winter tyre rated for some reason, as stated here:
http://www.tirerack.com/tires/tires.jsp?tireMake=BFGoodrich&tireModel=All-Terrain+T%2FA+KO&sidewall=Blackwall&partnum=675QR6ATAKO10&tab=Sizes
The S rated ones would've been fine, but I bought these second hand, so didn't have much choice in the matter...
Hello Mr Slow
Have a nice trip
Kind regards
Ole.
Hi Ole,
Thanks for the advice. Looks like Denmark won't be a problem then.
Posted
Ah... that sucks. :unsure:
But... I should still be fine if there aren't any wintery conditions, correct?
During the period from 1 December to 31 March there are special requirements in Sweden on which type of tyre a certain vehicle is to have when there are wintry conditions on the road. These requirements apply to both light and heavy vehicles' date=' as well as for vehicles registered in Sweden and abroad.
[/quote']
Right now it's not even freezing in Lund, so unless it starts heavily snowing or icing over there shouldn't be a problem. I probably won't be using the car much when I'm there anyway, just to get there and back and to do some moving :ph34r:
Posted
Have Sweden not just introduced new legal requirements for the use of tyres, chains etc for winter driving?
Norway is following as they are getting fed up with EU drivers that havn't got a clue, no chains, worn out
summer tyres etc, jacknifing and blocking the roads.
Posted
The new legislation is more aimed at lorries (this time around) where we must have on the steering axle and drive axle "winter" tires with a minimum thread depth of 5mm. The stringent legislation for cars hasn't changed much but I can add that I do know that the police are doing more vehicle (EU vehicle) checks when they enter the country, checking tires, paperwork, etc.
Add to the list of "getting fed up" is causing accidents that result in the lost of life due to poorly equipped EU vehicles for Nordic road conditions.
Todd.
Posted
Regarding Germany:
Op 26 november 2010 werd in Duitsland een nationale wet gestemd die definitief de regeling rond winterbanden in een wetgevende regeling giet. De vorige wet was te vaag en zeer vatbaar voor interpretatie. Deze wet is dus ook van toepassing voor toeristen die Duitsland bezoeken, al was het maar tot Aken. De boete varieert van 40 tot 80 euro voor wie niet met gepaste banden rijdt. Toch belangrijk om weten is dat 'winterbanden' een ruime omschrijving kreeg en M+S ook onder deze regeling vallen.
In short English: yes, even foreigners need wintertyres but M+S types are also considered as wintertyre
Posted
Info: -5 degree in Denmark now and snow is coming from east over sweden for the next 14 days, says the forecast.
Better get those winter tires on....
Yes they do check vehicles at the border for time to time.
Posted
Well, that's bad news :( It won't be easy (nor cheap) finding winter tyres in Belgium for a P38... but I'll have a look around.
