defender dinky Posted January 8, 2013 Posted January 8, 2013 hi, is the crankshaft pulley on a 200tdi defender engine that runs thee power steering pump the same as the discovery engine crankshaft that runs thee air con. dd Quote
western Posted January 8, 2013 Posted January 8, 2013 there are 2 versions 1 with 3 grooves for V belts which can drive the PAS Pump seperate belt in forward groove, Alternator & Water pump sharing a belt in rear groove, Air condition pump belt in centre groove. IIRC most Defender spec 200tdi came with a 3 groove pulley as standard [mine did] 1 with 2 grooves which can drive PAS pump on a seperate belt, water pump & alternator sharing a belt Defender & Discovery 200tdi pullies have different part numbers Defender ERC6859 use this instead http://www.lrseries.com/shop/product/listing/5277/ERR3093-CRANKSHAFT-PULLEY.html or ERC6861 no longer available Discovery ERR2351 http://www.lrseries.com/shop/product/listing/5234/ERR2351-PULLEY.html?search=ERR2351&page=1 or ERR2352 http://www.lrseries.com/shop/product/listing/5235/ERR2352-PULLEY-CRANKSHAFT-200TDI.html?search=ERR2352&page=1 Quote
defender dinky Posted January 8, 2013 Author Posted January 8, 2013 there are 2 versions1 with 3 grooves for V belts which can drive the PAS Pump seperate belt in forward groove, Alternator & Water pump sharing a belt in rear groove, Air condition pump belt in centre groove. IIRC most Defender spec 200tdi came with a 3 groove pulley as standard [mine did] 1 with 2 grooves which can drive PAS pump on a seperate belt, water pump & alternator sharing a belt Defender & Discovery 200tdi pullies have different part numbers Defender ERC6859 use this instead http://www.lrseries.com/shop/product/listing/5277/ERR3093-CRANKSHAFT-PULLEY.html or ERC6861 no longer available Discovery ERR2351 http://www.lrseries.com/shop/product/listing/5234/ERR2351-PULLEY.html?search=ERR2351&page=1 or ERR2352 http://www.lrseries.com/shop/product/listing/5235/ERR2352-PULLEY-CRANKSHAFT-200TDI.html?search=ERR2352&page=1 thanks western, Quote
