Posted
Hi guys,
accidentally broke the the 5 way fuel splitter on my td4, today, its located on the chassis rail, front left by the steering arm. does any one know where I can get one from asap, or does any on have one i'm stuck in eastleach at the moment but will be able to get someone to get it for me, if anyone one can help it would be much appreciated.
Many thanks
theoptimist
Posted
Try Tim Fry Land Rovers in Cheltenham, Bourton Land Rovers in Bourton-in-the-Water or Ellisons in Ashton Keynes ;)
Harry
Posted
brilliant thank you already tried tim frys waiting for a reply at the moment can only sell the it with all the fuel lines as apparently it is a job to get it to seal.
Posted
No worries :)
If you get really stuck you can always try TH White near Wootton Bassett, but prepare yourself for main stealer prices.
Harry
Posted
Can you not bodge/bypass it, it's only for diverting fuel round the cooler isn't it? In this weather you'd think it would survive OK without for a while...
Posted
according to all of the garges and breaker yards you can't bodge this due to the, how its laid out they have tried to work out different ways of doing just had an estimate from thwhite Swindon as tim frys can't do it next week 950 inc vat, plus recovery to pick my freelander up and get it there. tim frys were the same. glad i was sat down when they gave me that quote!!!! unfortunately they have my nuts in a vice as have no choice need my car desperately, due to where i live its a 1.3 mile drive way before you get to the road then steep climbs to get out, we have one car abandoned at the farm and the farmers cars stuck in front of his house due to the snow, can just about get about, as we have a disco but not road legal, cops wont be able to catch me in this weather thou so all good,
cheers the optimist
Posted
hi guys going to try to get a photo of the splitter up here but I was thinking, The feed pipe must be going straight through and the return would be where the auxiliary would be coming from or vice versa, if this is the case surely i could put a pipe connector connecting the feed straight through and a t piece to feed the auxiliary, this piece would have a valve in it would it? Does any one know how this flimsy bit of plastic works, as dealers wont tell me anything.
Many thanks
Theoptimist
Posted
Hi guys if i tried using the T piece and the male to male pipe connector could this damage the engine if it didn't work or would the ecu flag up a problem, or could it not see a problem and damage the engine,
many thanks
Theoptimist
Posted
Hi guys,
hope this may help someone else just found that the BMW part 16 12 1184632 works if pipes are adapted, So looking for this part will keep posted when fitted let you know how it goes.
many thanks
theoptimist
  • 5 years later...
Posted
Many thanks
Theoptimist
Did you have any luck locating one
Posted
21 hours ago, Rayburgo said:
Has any body got any idea were you get this 5way fuel splitter  I am  realy stuck need advice ASAP thanks
Done a quick fix glued the broken piece back put sealer over and covered it in approx resin found it usefull to insert a tent peg through the broken of piece and in to fuel line while Glue set it back in place now an re attached pipes hope this is use full but it works
