Disco handbrake problem.....help the newbie please ;-)
Posted
Hi all, new here so please be nice. I just bought a 1993 Discovery 1 , 200tdi. My problem is the handbrake doesn't work and the handbrake handle inside keeps being pushed up (like its on a spring)
Does anyone know the cause of this please.
Thanks in advance ;-)
Posted
I imagine either the cable or the expander is siezed. With my 110 it was the expander, You need to strip the handbrake and clean and lubricate all the mechanism. Or better still do what I did and throw it all in the scrap metal bin and fit an X-Brake.
Posted
Unfortunately that is way too expensive for my £800 discovery 200tdi. I'm just looking to replace or repair the standard (cheap like me) disco parts.
Posted
It's probably just the cable. Unless they are regularly drowned in silty mud up to the doors, expanders rarely give problems these days. Even if it is the expander, if you strip it down and clean it up and lubricate it, it will probably outlast the rest of the vehicle before it gives problems again.
Posted
Hi Shane,
Is there any sign of oil comming out of the brake drum? If so then the transfere box oil seal has gone and that's why it's not holding. Brake shoes are contaminated.
HTH,
Griff
Posted
No its not just not holding....it doesn't appear to be connected at all.....the handbrake leaver inside just sits half way up.....when you out it down it springs up again
  • 4 weeks later...
Posted
So it turns out it was the cable.....it was pulled then got stuck ON.... oooops.
£15 new cable and bobs your uncle.
While my mechanic man was under there i had him change the steering damper which was 100% buggered and he noticed the full thing has been poly bushed up.
Great for me eh?
So my £800 Bargain Disco 1 really was a Bargain...Passed the MOT straight away with no advisories. Im a happy chappie :i-m_so_happy:
