leepeet69 Posted May 17, 2013 Posted May 17, 2013 I have a defender 90, fitted with a 300tdi disco lump, I have 2 r380 gearboxs 1 is out of the discovery and the other is out of a defender! My problem is that both bell housing are the same length, I thought the defender bell housing would of been shorter?? Or do they vary between 90/110/130? I know they are different boxs because the sticks are the other way round, hope that makes sense! Quote
dave1607 Posted May 17, 2013 Posted May 17, 2013 I believe that the boxes are the same length, just the selector is in a different position, I think you have to strip the box to sort this, there are quite a few threads about this http://forums.lr4x4.com/index.php?showtopic=63630&hl=strip#entry550736 Ashcroft do an adapter if you don't want to strip the box http://www.ashcroft-transmissions.co.uk/index.php?act=viewProd&productId=375 Dave Quote
Aragorn Posted May 17, 2013 Posted May 17, 2013 Defenders before the 300tdi came along had a short bellhousing, and the engine sat right at the back of the engine bay. When the 300tdi was introduced in 94, they standardised the bellhousings across the range, so the defender got the longer discovery length bellhousing, and the engine was moved forward. So yes, the two bell housings will be the same length! Quote
western Posted May 17, 2013 Posted May 17, 2013 Defenders before the 300tdi came along had a short bellhousing, and the engine sat right at the back of the engine bay that's the 'stumpy' bell housing version for 200tdi's & earlier 4 cylinder engines, got one of these in my '89 110. looks like this http://www.ashcroft-transmissions.co.uk/index.php?act=viewProd&productId=157 Quote
Snagger Posted May 18, 2013 Posted May 18, 2013 Stumpy R380s were made, but are rare. I think they were made specially for retro-fit into MoD 90s and 110s on the refurbishment projects. Quote
